i found this on rotella .com
what do you all think?
"Upper cylinder lubricants" will find their way into the top ring land
and begin to "build up" a varnish. This varnish,over time will cause
the ring(s) to stick,then eventually the ring will seize in the bore
because the varnish has built up so much that there is no place for
the ring to go (but out.) The upshot is that the ring will
break,causing loss of compression,head/valve damage. It can happen in
diesels as well. I've seen teardowns with the use of UCL's and most of
the rings are stuck. That is the beauty of Rotella T, it keeps
ringlands super clean. It's that "high detergency" in the additive
package that makes a good oil-great!
