It's not open yet, but will be when I have the tool that comes in shortly(Wednesday at the latest)
This is a $16 MSRP filter that I bought for $8.13 and then paid using my preferred customer rewards card
cost to me= $0
I have high hopes for this filter, it seems to be a contradiction so far but I would love the idea of having a good quality OEM filter to use in the Caddy. It should also be noted that as of today, when I purchased the filter, I was informed that they are discontinuing this part number (whether there will be another gold PF48 or if they're introducing a new PF48 that will meet the ultra's guidelines wasn't clear)
Here are the initial noted features;
Box description notes nothing of efficiency rating but does mention the ADBV and the higher burst strength ratting
The Front face
Nothing here, move along
The silicone ADBV-- this seems to be totally un-necessary given all of it's applications are mounted 100% upside down. Oil doesn't drain up into the sky last I checked.. I want to say that the base plate is coated though? It doesn't look like the mild steel of other filters I've seen recently.
you can see through my poor photography skills that this indeed has a pressure bypass valve. Inital versions of this did not have such a valve, my guess is that there's a valve already somewhere in the drysump system of the LS7/9
a small glimpse of the media and metal core
Looks like a PF48 , smells like a PF48 internally.
so thus far we have what appears to be a $16 filter based on a $4 filter with an un-necessary ADBV upgrade and probably better sealing o-ring and thicker steel for the casing. Weight is fairly light. Couldn't commit to a number but the Napa Platinum and other high-mid tier products seemed to weight more.
I'll update the thread when I get the cutter, but suffice to say, I'm starting to appreciate the fact that this didn't cost me anything, and the Napa Platinum doesn't seem to be in any danger of finding a replacement.
cost to me= $0
The Front face
