I bought a UPF48R filter assuming a silicon ADB and received what appears to be a Nitrile. I then found photos of both online. Do you know what this filter is supposed to be built with?
Any oil in the filter and galleries that is located above the level of the oil in the pan can still drain down to the level of the sump if the ADBV leaks. Gravity will try to push the oil down to the level of the oil in the sump if there is nothing in the path to stop it.
