Is it overkill using higher priced, top of the line, modern oils in engines that were designed/manufactured years ago under older, now outdated, specifications?
For example - my engine is a 2016 Ford 3.5L Ecoboost. The oil spec in 2016 was SN. The industry has now gone through not just one, but two, more advanced specs since then. So I’m pouring in SP/GF-6 oils when I do oil changes now. Any SP/GF-6 rated oil should therefore be far superior to the SN oil my engine is “expecting”.
So, isn’t it safe to say that using ANY SP/GF-6 rated oil (of the correct viscosity) will be absolutely great in this engine? Why spend more money on something like Castrol Edge, Mobil 1, Pennzoil Ultra, etc, etc, when a less expensive option is available (Motorcraft, for instance)? If Motorcraft 5W-30 SP/GF-6 already exceeds the design parameters for my 2016 engine, what good is it to spend additional money for a “more advanced” synthetic oil? Heck, even SuperTech SP/GF-6 oil should be better than any oil from 2016, right?
The oils themselves continue getting better, but an engine will be stopped in time, at THAT particular oil industry standard.
Serious question, and replies would be much appreciated.
