Flipped through the owners manual of the new VW Jetta on friday (nice car, BTW). Oil spec calls for a product meeting VW 500.00, VW 502.00 or VW 505.01. Note that the VW 500.00 and VW 502.00 specs have been around for 5-10 years already.
As I've mentioned, one of the main reasons for this VW 505.01 spec is so VW dealers can consolidate the confusing array of oils they carry. The old 5w-40 Syntec is only VW 502.00/VW 505.00 rated as you may recall.
I believe what you'll see is VW/Audi dealers start to stock only the 5w-40, Castrol VW 505.01 rated synthetic and using it for VW 500.00/VW 502.00/VW 505.00/VW 505.01 applications. In other words, VW/Audi gas engine as well as older TDI's and the newer PD TDI's.
This dual use is one of the main reasons for the reduced sulphur, sulphated ash, phosphorus (SAP's) levels in the VW 505.01 formulations. It's also why these oils pass the ACEA A3 and VW 500.00 gas engine specifications....
Now if I could only get the misguided folks on the TDI Club forum to understand the significance of the VW 505.01 spec....
Ted
[ April 03, 2005, 11:38 AM: Message edited by: TooSlick ]
Ted
