Updated Efficiency For Stratapore Filters ?
Louisiana
As the title says, has anyone else noticed the efficiency difference posted on the FleetGuard site ? It used to show 30 microns @ 100% and now it shows 24.6 microns @ 100%. Per the FleetGuard website:
Interesting.
Could it be that they recently upgraded test lab equipment, giving them better resolution, and the ability to more accurately report filtration? Or have the made improvements to the Stratapore filtration media? One would think that if it was the later, they would make a deal about advertising the improvement in filtration efficiency.
Interesting.
Yeah Im wondering if that’s what the (c) is on there for. Corrected.
The image above is for the LF16035 but I have seen the same efficiency rating change on some of the other Stratapore filters.
That's oddly specific... where does the number come from?
it comes out suspiciously close to .001 inches... wonder if its related
Showing the value out one decimal, where it was reported in a whole number before, supports the idea that new test equipment can provide increased resolution.
When the test is done, an efficiency vs particle size curve it generated from the measurements. When the curve is generated, the point where the efficiency is 100% happens to be at 24.6 microns. Don't think the particle counter can measure particles down to a 1/10 of a micron.
Here's an example. The graph is produced from the particle counter equipment and plotted. If the graph is extrapolated to the 100% efficiency line, then in this case the efficiency at 100% is around 51.3 microns. Per the ISO test spec, they should be giving the efficiency at 98.7% (defined as "absolute efficiency"), but FleetGuard has extrapolated the efficiency curve out to 100%.
So at 98.7% it should be an even lower micron rating ? 24.6 @ 100% seems pretty good for a diesel engine filter.
Noticed it the other day when looking at a cross reference filter, didn’t think much of it till you mentioned it now. Fleetguard makes really good filters, only one that really beats them in efficiency is the Donaldson blue or Syntec media type filters.
Im envious of the filters Ive seen that you have cut open and the color of the used oil. Mine look like asphalt.
