Pete591, I am going to mow my Dad's lawn on Wednesday, but today I went around with my 6 HP Briggs push mower and did some trimming where I cannot get the Cub Cadet in certain areas, I mowed for about half an hour.
This mower is 12 years old and I have Amsoil 4-Cycle 30 weight synthetic oil with 3 ounces of MMO, I took a temp reading when I was done by aiming the infrared gun down the oil tube, so hopefully I hit the oil.
The temp I got was 180 degrees, I am not sure if your way of doing it with a thermometer or probe that is stuck in the oil is more accurate. The temperature outside was about 90 degrees.
I will report back with the reading on the Cub Cadet tommorow, this Cub Cadet has some sort of cold air scoop on it that goes over the engine and it has a cold air scoop on both sides, so basically you are not sucking in hot engine air, so I do not know if this will affect the temperatures.
This mower has about 80 hours on it, and my Dad is running about 3 ounces of MMO in the oil.
