1993 Briggs & Stratton 5.5 HP, 124702-3115-01 on a Toro 21” GTS II.
Dipstick reads right on full mark. When using the drain plug on the bottom of the engine only 16 ounces drains out (with mower sitting level). The manual says the engine should take 20 ounces. I called the dealer and he says the sump will hold back the extra 4 ounces and to just believe the dipstick. I have had the thing for 14 years and always kept the oil level on the full mark. I have never measured the quantity of oil drained out before and did not notice this discrepancy until it was filled up and ready to go for this season. Next time when I change the oil I will try tipping the mower to see if I can get more oil to drain out but figured I would ask here first. Can there really be 4 ounces of oil trapped somewhere in the engine? Thanks for any help.
