Originally Posted By: Johnny248
This is on an 09 Maxima,~20k. It is the Zex wet 50,65,75 kit running at 75 with good a/f mixture. I didn't think that it would really have any negative effect.
Ls1mike - Is there a reason you went with a dry kit over a wet kit?
Because an LS1 dosen't really need a wet kit until 150ish.
It runs through the MAF and my tune is set up to run a little rich at WOT. The kit only comes on at WOT, between 3000 and 5500 RPM, and with a enough fuel pressure. I installed an MSD window switch, full throttle switch and fuel pressure switch. I monitor A/F with a laptop.
All I do is turn the system on with one switch, turn the bottle warmer on with the other. The rest is automatic once you hit full throttle and 3000 RPMS.
Plus if for some reason your N20 pressure is low and you still dump fuel you can have a nitrous backfire, fuel will pool up in the intake and poof. Do a search on google, lots of videos to see.I also replace my N2O selnoid every year. That keeps it working nice.
Not sure why you neeed a wet shot for 75 unless your fuel system and tunning are not up to the task.
