I was just looking at a used oil analysis for the 5.7L Toyota V8 and noted that the oil capacity was nearly 8 quarts (my 4.7L Toyota V8 was about 7 quarts) and was wondering to myself how much the oil capacity would "change" the used oil analysis results.
As an example, consider a motor that produces exactly x amount of iron wear in a 5,000 mile period. The oil capacity is 8 quarts so in theory a single quart oil sample would contain 1/8th of the wear particles. If the engine were modified to only have a 4 quart capacity, the same single quart oil sample would have twice the wear particles and the used oil analysis would look significantly worse.
If my memory serves me correctly, a lot of domestic engines have significantly small oil capacities compared to some foreign engines. I had several people ask what I was purchasing oil for when I carried 7-8 quarts out of the store. Wouldn't it be expected for Toyota V8 used oil analysis to look better than a GM used oil analysis assuming the capacity's were different?
