DR T. The manual calls for changes every 7,500, including the first change. Dealer recommends the first change at 3,750. On my prev Volvo, the dealer made a big deal about not using Syn for the first 10K miles, and claimed that was directly from Volvo. This manual highly recommends Syn oils. IMHO, the Turbo alone warrants Syn.
moribundman & Spector - Regarding break in, I guess it depends on the definition. I consider the engine broken in as far as the need to baby the engine. I agree, from a used oil analysis perspective, this engine is not broken in yet.
RavenTai - I ordered the car, so the only time she sat was during transport (several months?). Got here with 6 miles on the odo, and I drive her 20 miles each way to work every day (mostly highway), with very few short stops. I also will let the car run when running in for a quick errand, such as when I get my morning coffee on the way to work (one block from home, so the car does not see significant throttle until fully warmed). This engine should have a good life compared to the average commuter engine.
Jelly - My research suggests that RedLine 5W30 would be an excellent oil, but I already have the Amsoil. I am on the fence on this issue as I could put the Amsoil in the wife's Murano and order some RL. Also, no GC in my area, and I refuse to use an oil that is not readily available, so that is not an option.
I would like to change the oil before Mid December when the temps start to really drop. The odo should read around 3K by that time, so I will simply plan on changing the oil in early to mid december. I will do a used oil analysis to serve as a baseline (and for grins and giggles). After that, I will probably change the oil every 6 months, or 10K miles, which ever comes first. I will probably due a used oil analysis every 5K just to make sure I am on track. Keep in mind that this car will see a lot of highway miles, so 10K miles in this instance should be equivalent to 5K-7K for many other people.
Thanks, DH
[ October 21, 2003, 11:24 AM: Message edited by: DockHoliday ]
