Hello all, I want to do some UOA testing of some transmission fluids when I get the chance. This is on a 5 speed manual transmission. Is there certain metals to look out for when it comes to transmission fluid analysis. Typically what metals make up synchros, and what metals make up gears ?. I would think those would be the two wearing items in the transmission.
The last fluid I dumped from the transmission seemed to have lots of visible metal flakes suspended in the fluid, I would expect particle analysis readings to be in the 1000's of ppms on transmissions. Lastly, is this similar to engine oil sampling, you try to take a mid-stream sample as you drain the fluid ?. Any info would be great thanks.
Joey
Joey
