UOA franken brew
montreal.qc
Hi fellow oil people Here is a used oil analysis on my FRanken brew
All 5w30 with 3 OZ of Lubromoly MOS2 thrown in
remarks from blackstone MICHAEL: Your engine doesn't seem to care one way or the other what oil you're using. Metals have been
remarkably steady through this batch of samples, and that comes despite using different oil brands. That
just goes to show you that low wear is more a function of the engine itself and the operation it sees than the
oil that's in use. No contamination was present here, and the viscosity read as expected. No moisture or
coolant was found, and insolubles are still in check at 0.3%. No problems found at 105,256 total km. Great engine!
OIL Valvoline conventional 2.5 qts / 1 qt CQ syntheic
KM IN USE 3,208 KM on oil (WINTER FILL)
KM 105,256
SAMPLE TAKEN 02/24/12
OIL filter Valvoline
ALUMINUM 2
CHROMIUM 0
IRON 3
COPPER 2
LEAD 1
TIN 0
MOLYBDENUM 102
NICKEL 0
MANGANESE 0
SILVER 0
TITANIUM 0
POTASSIUM 2
BORON 8
SILICON 6
SODIUM 218
CALCIUM 1847
MAGNESIUM 27
PHOSPHORUS 690
ZINC 748
BARIUM 0
INSOLUBLES 0.3 up from .2 (probly due to MOS2)
WATER 0
antifreeze 0
FLASHPOINT ºF 380
SUS VIS 210ºF 55.3
cSt @ 100ºF 8.87
fuel
Remarks could have very well been written by BillinUtah ( hes often said such things
What do you guys think Previos fill was Quaker State Ultimate Durability .
ANY interest in Pennzoil 5w30 VOA semi syn DEXOS!??
2004 Hyundai accent
The used oil analysis looks fine but you are at 1994 miles. The oil is not even broken in yet. TBN?
More useless B/S comments. Do they have a MUTE check box where you can avoid the comments. Better they provide a TBN and no comments.
Originally Posted By: gathermewool
IMO, 2 different oils doesn't consitute a Fraken-brew. Why such a short interval???
was winterfill short trips nothing over 12 miles , small sump 3.5 qts and wanted to see results of UOA. have gotten about same readings weather Pennzoil platinum or Quaker State Synthetic . This was a semi synthetic brew i made with MOS2 thrown in.
Cheers!
