I recently got a 2006 Chrysler Pacifica with all the options and only 64,000 miles. Garaged. Well maintained. All the things you like to see when buying a low-mile older vehicle.
But there is a bit of weirdness going on.
When I first got it, the battery was dead. So I was able to get it going with a jump. But only if I had an absolutely massive amount of cold cranking amps available AND I tried starting it up 20 or so times.
So I replaced the battery and drove it for a while. If I drove it every day, the issue wouldn't repeat itself. If it sat, then the cycle would continue.
One time I took it to a neighboring shop that can delve deeper into potential electrical issues. I was thinking it could be a bad ground or terminal. But everything seemed to be fine.
I start it up again after just driving it for thirty minutes... and it won't start. Then it does.
I bring it back home instead of keeping at the dealership to do some more digging. I get busy. It sits. Same issue. 20+ attempts to start it, plenty of starter fluid needed until it clicks. It runs. But then it dies about a half mile later going up the hill. It won't start up again.
Three days later I come back and it starts like there is no issue at all.
Here's the weird thing. I think I may have two issues going on at the same time.
First, the fuel pump. A new mechanic that I'm working with came to the last time it sat, and said there was no pressure coming to the pump. 20 years and a ton of sitting can kill the fuel pump.
Second, there is a TSB for the start / no start issue. Apparently when you replace motor mounts, like the former owner did, there is a healthy possibility you may pinch a part of the wiring harness and create this situation due to a pinched or broken wire.
It's frustrating and honestly, this is such a nice driving vehicle. I sell everything... but I also will drive whatever I sell for a solid 30 days straight if it has a mysterious issue that needs a deeper dive.
I'm wondering if I've missed anything. There's a guy coming tomorrow to replace the fuel pump. That may solve it. But I'm also thinking there may be some type of pinched wire near one of the motor mounts.
