Something I've been thinking about as the temps drop...
Truck of mine is equipped with an OEM auxiliary cooler setup; transmission pumps fluid up to radiator end tank where the coolant absorbs heat from the fluid, then returns to transmission. However, this circuit is entirely unregulated, and is without any thermostatic control.
In the cold days of winter running down the road at speed (long after engine coolant is up to temp) -- TC locked and lots of airflow -- you'll have a very difficult time even getting the gauge to move off from 100°F.
With such an emphasis placed on ATF viscosity and frictional characteristics, how can this be an effective/efficient strategy?
