On another site, they were having this big discussion about how the Toyota filter 90915-YZZB5 was the same as the Toyota 90915-20004. Since the 20004 costs $3.00 more, they were saying to buy the cheaper YZZB5. I went out and bought them both, hack-sawed them open and immediately discovered they are not the same. The 20004 had more filter material, a little "paper?" cog-like wheel down near the opening that was the same diameter as the filter and then there was this contraption on the end of the filter. Some sort of bent metal thingy shaped like an "H". Under this "H" in the end of the filter in the top was this circular shaped thing that was sort of stuck in the top of the filter material. THe metal pieces inside this quarter sized circular thingy reminded me of those mazes you would trace through doing puzzles as a kid. Is this the bypass valve?
[ December 28, 2002, 10:36 PM: Message edited by: Gebo ]
