A local guy has OEM BMW 7-series wheels (style 94) that I'd like to use for my winter setup. I've plugged this into a few of those "will they fit" calculators but I don't really understand the output. I used the OEM wheel/tire sizes since that's what I run in the summer.
Rear
poke: 102mm -> 77.6mm
inset: 152mm -> 125.6mm
Front
poke: 83.3mm -> 77.6mm
inset: 145.3mm -> 125.6mm
Those are the outputs, and it also has a graphical representation.
I *think* the fronts will stick out pretty much the same as stock (face of the wheel in the same position according to the picture), but the rears will sit slightly more inside the wheel wells. This fitment will be fine, right? Am I reading it correctly?
Rear
Front
