OVERKILL
$100 Site Donor 2021
When I seen it online I was kinda surprised. You could see some of the bottom and it was gray and the rust was on top of that. They appeared to be the same in the store. Maybe it was one batch or something but I’m not sure.
You definitely couldn't see any of the bottom of the can with the filter not cut apart, if you could, the media wouldn't be doing anything as the media doesn't seal against the bottom of the can, it seals against a spring assembly. It's a basic leaf spring with a valve in the centre of it in the basic FRAM filters, but other filters use a coil spring that butts against the bottom of the end cap if they use metal end caps.
