Under valve cover pic, '87 302HO
OVERKILL
$100 Site Donor 2021
Ontario, Canada
Here's what under the VC's looks like on my '82 Capri Black Magic. Engine is out of my '88 GT which I bought with 245,000Km on it. OCI's were 10-12,000Km with Mobil 1 of the following grades (in order):
5w30
0w20
5w50
5w30
I experimented to see how much the viscosity difference between a 20 weight and a 50 weight was going to be; ended up being 8psi hot at idle.
Never had a used oil analysis done. These heads have been on the motor since 285,000Km but I feel fully justified in posting this pic, as the E7TE heads (original) I took off were equally as clean. The lifter valley is also this clean. Engine now has ~330,000Km on it (it's actually higher, but I don't remember the exact number and am too lazy to go out to the garage and check
Gotta love the stock factory headers
One of the first things I replaced on my mustangs.
Gotta love mobil 1,for it's ability for keepin an engine clean!
Thats what I used on both of my mustangs,never had a problem with leaks,excessive burnoff,NOTHIN
Actually, those are MAC 1 5/8th's longtubes, the picture just makes them look funny, though they are "pinched" in the factory location to square them up for the exhaust ports.
When I first got the car the valve covers leaked. I also had an issue with the rear-main seal. New valve cover gaskets and a new rear main seal, which I did when I replaced the clutch (Centerforce), and it was leak-free.
Obviously since the motor is now modified (heads, cam, intake...etc) most of the gaskets are new.
I've always had very good results with M1, which is why I was quite surprised when I heard people coming down on it here.....
Originally Posted By: parimento1
did you ever have a problem with the engine seals leaking with synthetic oil??
I'm curious about this, too, as I have an 86 302 in a truck with almost 120k miles on it. Conventional oil its whole life. The mileage isn't that high, but it's a little old.
See post above yours :D
Ha! Guess I didnt notice they were Mac long tubes as mine (also have Mac 1 5/8 longtubes)still have the silver paint finish on them yet
I regret getting them,as they make swappin starters,transmissions a pain in the [censored]!
Oh, thanks. According to the times posted, I probably had my window open before you posted. Well, my rear main seal isn't leaking... yet. I would like to use GC 0w30 if I could.
I don't see a problem with that idea, as I said, I ran 0w20 in it for a winter and only saw an 8psi difference between the 0w20 and the 5w50 that I put in after the winter.
Ahhh, mine were the black painted ones and yeah, they are no longer black :D
I may re-paint them......
Have to get the car up and running again first though.
Originally Posted By: oily boyd
Looks excellent.
I love those rocker arms!
Those are the stock 93-95 Cobra rockers, 1.7 ratio, pedestal mount. They were made by Crane for Ford, and so they say Ford AND Crane on them and carry a tradition Ford part number
I have to change the valve springs still, those are Crane beehives, but I am replacing them with K-Motion K800's, as per my cam grinder's recommendations to run with my new cam.
Back in the day I remember reading that roller rockers reduce valve train friction by ~40% on that motor.
Please share some photo updates once in awhile!
Very possible, given that it has factory roller lifters, but the stamped steel rockers would definitely be a point of friction.
I have those Cobra rockers on both the Capri and my Town Car
