Did you happen to confirm AGM or EFB? If it's an AGM, there will be no sense in leaving it on the charger as it probably won't get above 11-11.5 volts. The battery is damaged/failed internally and no lengthy amount of charging will bring it back to fully usable voltage that will allow you to start and drive it without causing issue in one of the multitude of control modules, if not shut down while underway due to low voltage in one or more of those modules. If your dealer is worth their weight, they will have a tech come out and drop a new battery in it for you or provide a tow.
