http://www.clubgp.com/cgi-asp/mods.asp?modid=7
See a problem with it?
Also, it was mentioned in one of the threads there that using the pedal push method of braking is bad because the piston doesn't normally always compress, and it not only may be loosening junk past the normal compression point, but that junk might tear up the o-ring. Any thoughts on this?
