I have an E4od that is getting a code 62 converter clutch slippage. This is causing hard shifting only between 2to3 and 3to4th gears. It only shifts hard when at operating temp. Shifts great when cold. Would a type f fluid help the torque converter slippage which would then prevent the high line pressure causing the hard shifting? I know this may be a band-aid but the truck is only driven 2k miles per year.
