[img:center]
[/img]
I finally feel good about the bearing replacement in my S54 M Coupe.
First OA is the "PANIC VALUE" one that made me pull the oil pan to find #2 Rod bearing toast and the others worn a bit.
Next I tested the oil at 500miles to see what the inital break in wear was (driving under 3500RPM).
Now at 1500 miles post repair with no RPM limit I do not show much additional Copper or Lead. I feel good and will test the oil when drained (+ - 6000miles). Note: at 1500miles the TWS is still in grade...a 50Wt @ 6000miles in my first OA.
