Wow, just blown away by this discussion. FRAM has never failed to stand behind any oil filter product when used as it is supposed to be. Are you guys all lawyers with incredible warranty law experience? Your all splitting hairs. If your engine is healthy, you use the correct oil and a Fram filter and the engine fails because of a filter defect, we will stand behind it. We do not warranty failures caused by sticking pressure relief valves,incorrect part number for application, sludged up engines or a failure in maintenance. If you believe otherwise, i would challenge you to show me an example.
