I datalogged a few short pieces tonight if anyone wants to see what a turbo truck does on the highway and putting around through surface streets.
This is a 4 mile stretch of 4 lane highway with the cruise set on 75. The only two data plots selected should be boost/vacuum and speed.
The particular stretch of highway drops 100 feet in those 4 miles and then climbs back up a bit. Nothing big, just normal foothills of GA type elevation changes.
Now, this is a single turbo truck, but I'd bet tomorrows lunch money that the 2.7/3.5 wouldn't be using any more boost to move a slightly bigger truck through the air. Truck is in 10th gear the whole time, fully warmed up, etc etc.
Here's a static image where I drew in the 0 boost line. Below the line is vacuum above is boost. The link to the interactive chart will let you see more pinpoint data.
Cruising down the highway, at 75, the tuck is in vacuum a bit more than you would suspect. The couple bumps in the first 1/2 are slight inclines, and the 10psi peak at the end is a little bit steeper hill.
Interactive Chart:
datazap.me
This second chart is about 3 miles of surface street driving with a max speed around 45. This is through neighborhoods, so you're pretty light on the throttle. Almost never truly in boost, although very close.
Interactive Chart
datazap.me
Just thought some people might like to see something like this. These turbo trucks are far from just boiling the snot out of the turbos at all times.....well, unless I'm towing, then it is, but even then, on flat highway it is still nowhere near the max boost (21psi) unless I'm really wanting to get moving or dealing with traffic messes.
