Originally Posted by kschachn
Originally Posted by wag123
Streaming HD video will quickly eat-up all of your monthly cell phone data allotment.
One summer a while back my daughter stayed up at college because of her summer job. She didn't have wifi at her apartment so I bought her an HDMI adapter for her phone. Her average usage that summer was around 60GB of data per month but that included a lot of binge watching Gilmore Girls at night.
Some carriers will throttle data after a certain threshold or if there is network congestion, but it can be done. It also has a lot to do with the cell phone signal you are getting at your specific location and what kind of data connection they are using from the tower. But if those are good and you have either a large allotment or unlimited data then it is doable. We have unlimited and as far as I know they didn't ever throttle it back or anything.
My wife has AT&T with "unlimited" data. The actual limit is 22gb after which they "can" throttle the connection.
https://www.att.com/help/wireless/data-usage.html
I have T-Mobile with "unlimited" data. The actual limit is 50gb after which they "can" throttle the connection.
https://www.t-mobile.com/customer/mydatausage.html
They may or may not actually throttle your connection at any given time, depending on network congestion, but, once you have exceeded your data "limit" in any given month, they can throttle your connection at any time for the remainder of the billing period. Also, when you are out in the boonies, you may not have a fast enough connection to stream HD videos.
It won't take very long to exceed their limits when you stream HD videos, for example...
I have cut cable TV at home and now use my Spectrum 100gbs Internet connection for streaming Philo on two TVs. My average data use per month is 600gb. The first month that I had Philo (after cutting my cable TV) I exceeded 1tb of data use and Spectrum throttled my connection. I am now much more careful about how I use it. The point I'm making is this... when you are streaming HD video, the data use can add-up fast.
The only other alternatives the OP has are...
OTA (over the air) ATSC TV using an antenna. But, the outside reception limit using a good directional amplified antenna is 80 miles (but the practical limit is more like 60 miles) so one would have to camp fairly close to a larger metro area that has TV stations.
Satellite TV using a dish. This is the best option for avid TV viewers. But, don't mount the dish to your RV. You won't get a signal under the trees. Purchase a portable dish with a long cable so it can be moved/positioned out from under the trees.
