turning old Dell into a multimedia PC
Southeast Michigan
My father has a Dell Dimension 4600C desktop computer that recently hit "end-of-life" when the motherboard died. Because the computer was 8 (or more) years old anyway, he decided to upgrade and purchased a new Dell Inspiron 660.
The old 4600C is a slimline case and I was thinking about trying to "bring it back to life" and build a multimedia that I can connect to a TV and use to stream Netflix, etc. It looks like I can get a new motherboard for under $30 and assuming that is the only problem, I can get it back up and running with the following specs:
Pentium 4 2.6 GHz
2 GB RAM (which is the maximum)
80 GB HDD (ATA 100, EIDE, 7200 RPM)
I think Windows 7 with Windows Media Center will run sufficiently and that's really all I'd have installed and running. I'd then need to find a low-profile video card that I could send video+sound out on via HDMI.
What do you guys think? Worthwhile effort, or too old/slow to make useful for this?
That is a tad too slow for any real HD/multimedia use.
The good news is, you still dont need anything too modern to do what you need.
I am currently looking at a Core2Duo which for the price/performance is right in the sweet spot for a cheap HTPC build.
Actually considering just a prebuilt and saving myself some money.
I wonder if there's a faster motherboard/processor combo that will fit in that case? I generally hate proprietary, slimline cases like that. But in this case, it would lay on it's side and look similar to an Xbox on the shelf of an AV stand.
Yes, I think you could make it work. Full HD (1080p) would be a stretch, but anything under that might be usable.
What you really need is a fast and supported graphics card. That is going to be the main constraint for a HTPC machine.
I was planning to do basically the same thing with an old machine using a Linux version of HTPC software called Myth TV.
Link here: http://www.mythtv.org
XBMC is another option worth considering.
I was initially planning on running XBMC on a small Intel Atom-based box, but in the end, decided it would struggle too much. Ended up buying a lower end Dell machine in a slim tower case based on Pentium Dual Core E5300 and ATI Radeon 4350. It's not a speed demon by today's standards, but XBMC runs smoothly and plays 1080p with room to spare.
In my opinion, it is not worth putting time and new hardware around a Pentium 4. You have to pass the Pentium 4 generations altogether to reach worthwhile territory.
