Shel_B
Site Donor 2023
- Joined
- Aug 7, 2020
- Messages
- 5,167
I've been getting an intermittent indication (fast flasher indicator) that my left turn signal isn't working. Example: pulled out of space, turned the signal on, flasher was rapid. Drove a bit, turned the signal on, flasher was normal. At various times I checked the signals using the reflection from the car in front of me. The light does work intermittently.
Now, since the bulb does work, what other issues should I look for? Loose bulb? I'd like to do as much as I can by myself before considering a shop.
Thanks!
Thanks!
