I will do the smog check at the end of September.
In June I have an oil change, spark plug replacement, tie rod end job, PCV valve replacement scheduled. the air filter is clean. The oil will get changed once more
My car is a 1996. What about timing? There is no check engine light on. Is this a concern? The original factory settings in that regard have never been changed. It has always passed smog before. What else might you suggest?
It is a 1996 Toyota Avalon.
