Trying Diesel Oil in Kohler
USA
So I am dumping the 10w30 MC syn-blend from my kohler courage 26hp and switching to SAE 15w40 diesel oil (1 Quart) and a quart of SAE 10w30 diesel oil. Anyone think this will help clean the engine out before I switch to AMSOIL? And I am assuming this is probably a conventional lube, right?
And it says on the bottle "Do not use in gasoline engine equipped with catalysts."
Do kohler courage 26hp's have catalysts?
Alright! Thanks. And will the diesel oil help clean up the engine more than my previous oil?
I was running Rotella 5w40 in my air cooled engines for a couple years.
Right now I am running 5w40 Maxlife.
In 100+ degree weather I don't trust those tiny cooling fins to do a great job, and I want something synthetic so that it will hold up better.
I don't see why your mower shoulden't love 15w40.
I have Rotella T5 10w30 in the Kohler on my Simplicity lawn tractor. No intention of doing a used oil analysis, but everything seems fine. My engine is "clean" as-is, so I'm not running T5 for cleanup. What are you trying to clean that you think you need a Diesel oil over something else?
Do a google search for the model, and look at all of the results that recommend 10w30 as the heaviest oil that should be used.
