The sad thing is, most commercial truck drivers are simply steering wheel holders. You watch them at truck stops and such, and they will hardly ever "thump" a tire to check to see if it is even inflated before leaving, let alone stick them with a tire gauge. And there is so many "drop and hook" situations where trailers are exchanged every day or even several times a day. Again, proper pre-trips are not done.
I have over 3 decades in commercial trucking. I have NEVER lost a recap. NEVER. I stick my tires each and every day before taking off. I walk around and check things whenever I stop.
Virtually every time (99.9%) that a tire blows is what others have stated.... low air pressure, overloading, high speed, and a driver that didn't even do a proper pre-trip and check this stuff out. Commercial tires have various weight ratings and speed ratings. That is when everything is perfect. Put a knot head at the helm, and all sorts of interesting things happen.
There really is no way to effectively deal with the problem. Government regulation can only go so far. If a driver is not going to check things, stuff is going to happen. And that goes to another point, how could it be proven precisely that he didn't check things and maybe had tire damage from road debris later and wasn't aware of it?
That being said, I can run around at 80,000 lb gross all day long, in 100+ degree heat, and never have a tire issue. Have done it for years. And have done it for years on recap tires. I like em, I use em. I save a grip of money in my operation by using caps. It costs $1100 dollars for just one wide based single tire for my tractor. I can get a Michelin cap for just under $500 with my casing trade in. For regular truck tires, a new can go for between $500 - $600 each. A cap..... around $275. And if you check with the Retread Tire Association, it has been shown, that with proper air pressure and maintenance, a cap tire will hold up as well, and even sometimes better than a virgin tire. The tire casing goes thru extensive X-ray and other analysis before a cap is even considered.
The Retread Tire Association will provide a free pass to anyone who wants to tour a retreading facility and check this all out. Michelin has several videos online showing the process.
http://www.michelintruck.com/michelintruck/tires-retreads/retread-process-video.jsp
