Is this OK to connect the "positive wire" of the trickle charger to either of the 2 bolts in the yellow circle? The permanent quick connect will be installed at the trunk under the spare wheel where battery is also located. The wire of the trickle charger is not long enough so I am moving it connected in the fuse box so that it will be easily accessible without moving the cover of the spare wheel. Please see picture below.
I am afraid I might fry the car's ECU so I am consulting the professionals on this forum first.
Thanks
Thanks
