Transynd for my Ford truck??
Poco B.C. Canada
I have a Ford F-250 1977 with a C6 transmission, it does not use the Type-F it is the one that uses Dexron.
So my question is I have access to some Transynd synthetic transmission fluid and am wondering if I can use it.
Some have guessed I can and say they will use it in there GMC's, but is it okay with my type.
Amsoil sells a Torque Drive fluid that is supposed to be a direct replacement for Transynd.
Looks to me like it might work. That is the time frame when Ford was switching over to Dexron II fluid I believe. The only thing is yours Dexron II or III?
I'm sure others will chime in........
Torque-Drive™ Synthetic Automatic Transmission Fluid (ATD)
Recommended for use in applications specifying Allison® TES-295 or C4, DEXRON® III, MERCON®, ZF® TE-ML 14C
See Pricing Information or Place an Order
Package sizes include:
1-Gallon Bottle
1-Gallon Bottles (case of 4)
2.5-Gallon Bottle
2.5-Gallon Bottles (case of 2)
16-Gallon Keg
30-Gallon Drum
55-Gallon Drum
275-Gallon Tote
Engineered to eliminate the deficiencies common to all conventional, petroleum ATFs, AMSOIL Torque-Drive™ provides superior performance and protection against thermal and oxidative degradation, sludge and varnish formation, viscosity shear down, cold temperature oil thickening, poor friction stability, high component wear and shortened oil life. Automatic transmission operating expenses can be directly linked to transmission fluid quality. Poor quality oils need frequent changes and they reduce the effective service life of transmissions. Delivering the ultimate in oxidation resistance, wear control and friction performance, AMSOIL Torque-Drive™ extends lubricant life up to six times* and provides protection beyond that possible from conventional ATFs. Vehicles stay on the road longer, unnecessary labor and maintenance costs are reduced, and the return on costly transmission investments is maximized. Immediate financial benefits are realized upon the installation of AMSOIL Torque-Drive™.
* Depending on duty cycle, local conditions, oil analysis and/or OEM recommendations.
THERMAL AND OXIDATIVE STABILITY
Hot weather and operating conditions are no excuse for poor transmission reliability. By delivering a slower than normal oxidation rate, AMSOIL Torque-Drive™ prevents sludge that blocks small valves, prevents varnish that restricts component movement and reduces oil thickening that slows down shift times. AMSOIL Torque-Drive™ lasts longer than conventional ATFs, protects better than conventional ATFs and extends transmission life beyond that possible with conventional ATFs.
SHEAR STABLE
Conventional automatic transmission fluids use petroleum oils with viscosity index (VI) improvers added to increase the oil’s operational temperature range. Over time, VI improvers shear down, promoting premature wear by leaving only a thin base oil to protect vital transmission components. AMSOIL Torque-Drive™ does not contain VI improvers, which means no VI improver shear down regardless of the operating environment. The unmatched film strength of AMSOIL Torque-Drive™ prevents wear, significantly increasing the transmission service life.
FRICTION DURABILITY
Oxidation by-products destroy the sensitive friction characteristics of transmission fluids, resulting in the rapid degradation of shift quality. The thermal and oxidative stability inherent in AMSOIL Torque-Drive™ assures consistent, smooth clutch engagement with no harsh shifting throughout the life of the fluid. AMSOIL Torque-Drive™ maintains proper coefficients of friction, prevents clutch glazing and prevents elongated shift times.
EXTREME TEMPERATURE PERFORMANCE
Transmissions operate in temperature extremes. In hot temperatures, the synthetic construction of AMSOIL Torque-Drive™ virtually eliminates oil evaporation and delivers a better lubricating film than conventional oils for better overall protection of vital components. Oil consumption is reduced and transmissions require less maintenance.
In cold temperatures, AMSOIL Torque-Drive™ easily flows, as it does not contain the wax found in conventional ATFs. Cold temperature fluidity allows for the proper operation of small, delicate, electronically controlled solenoids that affect gear changes. Unlike conventional ATFs, transmissions using AMSOIL Torque-Drive™ have quick response times during cold operations and can be used immediately upon start-up.
AMSOIL Torque-Drive™ Synthetic Automatic Transmission Fluid is based on the same type of chemistry as TransSynd®. This fine Infra-red (IR) scan, revealing a chemical "picture" of both products, shows no measurable differences.
AMSOIL Torque-Drive™ Q&A
PHYSICAL DATA
AMSOIL Torque-Drive™ Synthetic Transmission Fluid (ATD)
Castrol/Allison Transynd® Synthetic Automatic Transmission Fluid
Physical Data Torque-Drive™ TranSynd®
Kinematic Viscosity @ 100°C, cSt (ASTM D-445) 7.41 7.36
Kinematic Viscosity @ 40°C, cSt (ASTM D-445) 37.14 37.29
Brookfield Viscosity @ -40°C (cP) 8411 8400
Density @ 60°F (lb/gal) 7.038 7.047
Flash Point °C (°F) (ASTM D 92) 230 (446) 232 (450)
Pour Point °C (°F) (ASTM D 97) -55 (-67) -55 (-67)
Four Ball Wear Test
(ASTM D-4172B: 40 kg, 75°C, 1200 rpm, 1 hr) mm 0.45 0.45
Copper Corrosion (150°C, 3 hr) 1B 1B
Spectrographic Analysis
Boron (ppm) 133 136
Calcium (ppm) 28 29
Phosphorous (ppm) 230 235
I don't believe any Ford transmission has ever been spec'ed for Dexron ATF...that is a GM fluid spec.
This transmission needs a Mercon ATF, right? Most Dexron-III ATFs are dual licensed for both Dexron and Mercon, but not Castrol Transynd. Transynd is licensed for Dexron-III(G), Allison TES-295, Allison C-4 (no relation to Ford C-4 transmissions), ZF, and Voith. Not Ford.
Stick with your choice of a Mercon ATF.
Ken
Years ago, lubrizol had the ATF specs on their website. There was so much overlap and similarities between dexron and mercon that I couldn't see any reason why it wouldn't work.
TES295 would be a excellent upgrade to the regular Mercon fluid. I just would NOT use it where MerconV is required.
And, because of the cost of it and other synthetic ATFs, I would definite make sure that the cooling and filtration are upgraded. This way, you can use the ATF a very long time(which is the primary purpose of the boutique ATFs).
Ford did spec Dexron fluid from about 1977-86ish. Untill they came out with Mercon.
I remember because I had an 83 LTD that took Mercon. At the dealer we used 90% Dexron in the Fords and very little type F fluid. I worked at This Lincoln/Merc dealer in 1987 and they had a Ford tech magizine I read.
It had all the fluid specs for the different years and different Ford transmissions.
In fact I had kept it as a reference up until about 10 years ago.
I thought it was weird that a Ford speced a Dexron fluid.
