I know it's a transmission problem that needs expert attention. All I would like to know is the possible causes of this problem, so that I'm armed with some knowledge when dealing with the mechanic.
The problem is: Transmission does not engage immediately when shifted into "D". It can take up to 5 seconds and some gas before it engages. I did a drain-and-fill of the ATF (temporary measure) and it's slightly better.
Inputs will be much appreciated.
Thank you.
Thank you.
