Transmission Pressure?
Long Island, NY
I have a 1998 Mustang Gt with the 4r70w auto transmission. What should I set the transmission pressure on my diablosport predator tuner to?
Right now i have it set as
1-2 Shift- 30psi
2-3 Shift- 20psi
3-4 shift- 20psi
what psi is best for the transmission
If you are talking EPC pressure, on my '97 SHO with the AX4N and transgo kit and Xcal2 tuner I see about 75 lbs for max pressure. 35-45 under normal conditions.
There is no best. Just set it to what you like.
From what I understand, those "psi" readings aren't final. It is either the increase in stock PSI or the increase in PSI by %'s.
