I had a friend weld a B and M drain plug kit onto a NOS pan for me to install on my next fluid drain. I bought some cheap $1 fluid to test it and it leaked.. even with the fluid being cold. Not too sure if the weld warped the plug kit or if its just expected to have to add a sealer to the threads. What would you guys recommend? Pipe tape? Heck I don't even know what I should torque the tapered plug at.
Or is it not even worth adding the pan with plug because of the fear of it leaking and losing fluid? It has me second guessing myself. 1 mess every 30,000 miles seems slightly cheaper than a transmission.
