Transmission Fluid Seepage
Thanks BD for the Mag Hytec recommendation. A little out of my budget right now, plus I don't want to get into modifying trans support and need to make sure all this is going to work once put back in service.
I had dealer order second pan...still the same, so I went to work on the 1st new dealer pan. Used a straight edge and the pan was pretty warped, so I started straightening it out with a body hammer and block (All those years of doing body work on rusted cars as a kid paying off).
Then I filed the ridges off the bolt holes and feathered down the ridges on the corners. Followed up with 220.
At this point, I might use Hylomar M on the pan surface to seal sanding marks, fill remaining voids at corner creases and seal exposed steel to prevent rusting.
[Linked Image]
[Linked Image]
Hey BD Cardinal,
Your 365.00 Mag Hytec recommendation is looking pretty good to me right about now
Turns out the transmission mount modification was for the Excursion, not the Expedition as I originally thought.
