On my 98 Expedition with 4R100 transmission, I have been chasing a fluid seepage issue. The truck is parked nose down on a slight decline of the driveway. I have done a drain, filter change and refill with Max Life Synthetic (Same as I have been running for years), Also drained torque converter.
Fluid appeared to be leaking around front pan bolts after the fluid change, so I removed pan, cleaned all surfaces on pan and transmission very well, put on new factory gasket (dry), torqued bolts to spec (10-11 ft/lbs). Refilled and it still leaks on bolt heads.
This picture is after 12 hours after wiping everything dry
Any ideas of cause and solution?
I am thinking of dropping the pan again and using Hylomar between gasket and transmission and between gasket and pan surfaces, but that is a last resort. I don't see why it should need any additional sealant, other than the new gasket...besides the fact that it leaks
