Today while at the my mechanic I asked him about my exhaust. It's better than it was but it still spews a light cloud on some accelerations and when first started.
He said that valve seals are probably leaking slightly. He suggested adding 1 quart of Transmission fluid to the oil to help clean the engine and soften the seals.
What are y'alls thoughts on ATF added to the Oil? I just did an oil and filter change after working on my oil cooler adapter. It's running 5 qts of 5w30 currently. Some other things I've been told may help is MMO, MOS2(which I couldn't find at my local AAP), and Seafoam.
Thoughts, opinions, advice?
