Transfer case flush?
Originally Posted By: Rob_Roy
I think you are making this more complicated than it needs to be. I understand that you want to get all of the old fluid out, but you don't need a solvent rinse to accomplish that. Take the truck for a nice ride to get everything warmed up, then drain the current fluid out of the t-case. Refill with some el-cheapo 80w90 and drive the truck normally for a week or so, then drain and refill with your preferred gear lube.
I would do this or just do a normal change with the fancy fluid. Or do a rinse with a quart of cheap stuff, poured into the fill hole and flowing out the drain.
Things can settle in the bottom of the transfer case and can be resistant to mixing by driving. I have a thread hear somewhere explaining my observation of MoS2 settling in my T-case. In the end, I used a big can of WD-40 to blast the gray mess out of the bottom of my T-case. Like the OP, I only had access through the drain and fill plugs.
I don't like the brake cleaner plan at all. Isn't it going to puddle in the bottom of the transfer case? How about this happy medium:
-Drain it out.
-Spray out the bottom through the fill hole using air if available otherwise using CO2 or "canned air" (usually a HFC that boils off in a matter of seconds) or propane.
-Replace the drain plug and add 1 qt of cheap Dexron type ATF.
-Drain it out.
-Replace the drain plug fill with suitable lubricant.
The ATF shouldn't thin the fluid you're leaving in there as much as parts cleaning solvent. Just using a bit of the lube you really want in there is even better if it isn't too expensive. Using something that's normally a gas at room temperature for blowing away the puddle means you don't have to wait so long as for parts cleaner to dry.
