Need to change the transfer case fluid out of my 01 suburban 2500 and can't seem to locate an off the shelf fluid. Does Amsoil have one?
thanks,
rob
thanks,
rob
Quote:
What does it call for?
Quote:
Autotrak is a friction modified ATF used to prevent slip- stick shuddering noise issues in those x-cases that were originally filled with Dexron.
It is recommended that you use autotrak.
RoyalPurple recommends the use of its synchromax.
Its funny that on some vehicles that I've driven with x-case binding on dry pavement, a simple shot of lubegard platinum eliminated the problem, instead of replacing fluid with autotrak. I serviced a few with Mobil 1 ATF and lubegard with no issues.
Since most multivehicle ATF's are friction modified, I would think that Valvoline MaxLife, Pennzoil or Castrol multivehicle, ATFs would also prevent the shudder issue.
Quote:
.. I serviced a few with Mobil 1 ATF and lubegard with no issues..
Quote:
[I'll get the fluid from the dealer, need a new diff cover anyway.
Rob
Quote:
This can be a bit of a minefield, it's best to follow the OEM recommendation.
Quote:
yes, get autotrakII fluid - you can get it at the dealer- the only place. Its dyed a rich blue.
Who knows, maybe it was Dex VI in disguise all along???![]()
JMH
