I e-mailed Amsoil's tech center and asked what fluid is recommended for the transfer cases in Sonomas, Sierras, Suburbans etc. from the 70's, 80's, 90's and up. I figured their ATF would do, this is the response:
"If these are manually shifted transfer cases, then our AMSOIL ATF is an excellent choice. If they are auto, then GM requires AutoTrac fluid and we do not have a replacement for AutoTrac"
How are the two types of transfer cases different? I think Amsoil would be the last company to tell you not to use their own product unless they really mean it. I have run Mobil 1 ATF in the transfer case in my auto 84 GMC truck for a long time and have not had any problems, but then again a lot of people use Slick 50 without any problems too? Any idea on wether or not to use ATf in auto transmission transfer cases or not especially in late model trucks, and if not what other than OEM fluid would work.
