I also thought that he already arx'd it.
Get the transmission rebuilt. For crying out loud, it has 168k miles on it, right? Its toast.
Or flush it with the CORRECT fluid and add nothing but the correct fluid.
Nothing but a rebuild fixes worn clutches.
Nothing but a rebuild fixes disntegrated seals(usually worn thin from excessive metal in ATF).
Its a cleaner and an ester too!
LUBEGARD® ATF PROTECTANT:
Reduces operating temperature, allowing transmissions to perform more efficiently
Increases thermal & oxidative stability of ATF for stop & go driving, heavy loads & towing
Reduces transmission wear, extends fluid & transmission life
Maximizes over all transmission performance
Helps reduce comeback & warranty problems for shops & mechanics
Insures proper & smooth shifts
Prevents clutch chatter & torque converter shudder
Eliminates objectionable noise (squawks) during shifts
Keeps valves free. Frees stuck valves in valve bodies
Prevents hung governors
Modifies harsh shifts & makes them quicker in duration
Can be used with all ATFs: OEM, Synthetic or Mineral Oil Based
Contains LXE (synthetic esters & synthetics)
