Originally Posted By: supton
I'd think truckers would of all drivers be most interested in such systems. Pick up a nail and have a slow leak? Since you guys are often driving for hours on end it may be a good while before a tire check could occur.
It has its place, no doubt. But the end user should be the one to determine that, and then they can get the system that most meets their needs. On my commercial trucks, not interested. And I have run wide based singles instead of duals for almost 1 million miles and not found a situation that the cost would have been worth it. Sure, I use it to take a look at pressures in the DIC on the pickup that I have it on, but as for replacing the sensors when they die, at the most it would be when tires changed out in the same way that DBMaster stated. I just haven't come across anything with my vehicles, commercial or personal, where TPMS is worth the cost.
My biggest gripe and really the main reason I don't like TPMS from the OEM, is that it is set up for what the OEM decides I should run the tire pressures at. On my Chevy 2500 with E rated tires, I don't follow their recommendation, so the TPMS is always having a fit. They recommend 60 psi up front and 70 psi in the rear. Fine, if one is at gross of 9500 lb, which is what that pressure recommendation is based on. But for running empty or light loaded, I find better tire wear, better ride, and better handling by dropping the tire pressures to 55 psi all the way around. This is the similar methodology recommended on commercial truck tires.... base the psi on the actual load on the tires. It has worked well on my commercial tires, as I got 447,000 miles out of the last set of wide based drive tires on my semi. And it has had good results on my 2500.
Now if the TPMS allowed end user setting changes, it might be more tolerable. Asked a couple of dealers to change the TPMS to the 55 psi all the way around and none of them would do it. Claimed they couldn't, but that is not true. My guess is they didn't want to diverge from OEM and possible felt a liability concern.
