Think and know are 2 different things!I think it's a main bearing design flaw,
OK!last I heard.
OK!last I heard.
Nah. That is wishful thinking that I see on Toyota forums.If we're being charitable... it could be that Toyota does plan to do something about the hybrids once the non hybrids have been taken care of, however safety concerns would mean the non hybrid should have priority since the hybrid can still drive itself out of harms way if required when the main engine blows and they probably can't fix everything all at once.
That would be my guess. I do think Toyota will eventually get to the hybrids.
It is main bearing issue. There is nothing questionable there.Think and know are 2 different things!
OK!
That's obvious to everyone?Think and know are 2 different things!
That's obvious to everyone?My diction was intentional.
Toyota hasn't released information on what's going on exactly, so it's just been amateurs tearing down V35As and trying to diagnose the issue themselves... This was hard because the engines are replaced under warranty and go back to Toyota, so it's challenging to get an engine to tear down.
"I Do Cars" did an excellent teardown on a grenaded V35A. He tried hard to get one.
Can you explain this, would this issue happen if the engine was not DI. Something is not adding up?It is main bearing issue. There is nothing questionable there.
Oiling issue? Material issue? Some actually due to debris while others due to something else? Combination of these issues? You don't redesign the #1 main bearing when that's the failure point unless you're fixing a defect.Can you explain this, would this issue happen if the engine was not DI. Something is not adding up?
I think they were still blaming it on debris damaging the bearing at this point, but I'm no expert on this issue.They did release that the initial fix was a redesigned front main bearing or at least the 2026s have a newly designed front main bearing. I don't know what else we need to know...that's the failure point and they didn't redesign it for giggles.
"Toyota’s May 20, 2026 recall notice says the affected 2024 engines could still have debris that damages the #1 main bearing, and then states: “Engines produced after those included in this recall were manufactured with an improved #1 main bearing.” Toyota also says repaired vehicles from the earlier recall are being fixed using engines produced with that improved bearing."
https://pressroom.toyota.com/toyota-recalls-certain-2024-toyota-tundra-vehicles/
So is 5W40.
Just wait until they say: Rotella T6? OK during crisis, not after that.
Brotella’s will have a field day.
I'm cautious about the idea that they redesigned the #1 main bearing solely to handle debris better.I think they were still blaming it on debris damaging the bearing at this point, but I'm no expert on this issue.
You are not sure, that is okOiling issue?
Again!Material issue?
The debris thing, really!Some actually due to debris
Guessing!Combination of these issues?
Something is not adding up here? The #1 main bearing having a failure, this is pointing out to an oil issue. This is not a thick or thin oil thing, maybe someone letting the oil level getting low, or maybe letting the oil change go to long!You don't redesign the #1 main bearing when that's the failure point unless you're fixing a defect.
Yet, while Toyota did release the information on the redesigned #1 bearing, Toyota's official stance still is it's entirely due to debris, so your guess is as good as mine. I give them a mixed score here since they are doing something significant for SOME affected engines, but they still aren't telling us everything going on and they haven't committed to fixing all affected engines.You are not sure, that is ok
Again!
Guessing!
It was a jokeWouldn't the T6 15w40 be somewhat acceptable as it's SN rated?
AgreeI'm cautious about the idea that they redesigned the #1 main bearing solely to handle debris better.
How is debris still an issue? Did they design oil passages that are impossible to evaluate and clean? Is that a thing?
It was a joke
Yeah I'm sure that's what's accounting for the widespread failure. Toyota need not worry. We have @Brian123 on the case.This is not a thick or thin oil thing, maybe someone letting the oil level getting low, or maybe letting the oil change go to long!
Sure yeah run it.Wouldn't the T6 15w40 be somewhat acceptable as it's SN rated?
DI or not. It is bad design. It is I think oiling issue. There are several good videos that explain issue.Can you explain this, would this issue happen if the engine was not DI. Something is not adding up.
