I read it as blending too. If it's not meant to be, it's not worded very well.
They legally can't unless the EPA gives them approval. Even here, the substitutions they're doing are still the same single use-case that is already permitted (one OCI at the higher weight and then you must go back to the specified weight on the next fill), they're just doing it at the dealership level for the whole fleet.Yup I don't see Toyota green lighting the use of 5W-30 or higher. They're still be conservative
No and above freezing there's no difference.100% Self inflicted issue. Is 0W-20 or 5w-20 really TOO THICK? Seriously?
I was going to point out that Toyota (and others) do mention in the owners manual things like "if 0W-8 isn't available, you can sub 0W-16 this time but must switch back at the next oil change". You're saying that's a loophole or workaround to EPA / CAFE compliance ?Even here, the substitutions they're doing are still the same single use-case that is already permitted (one OCI at the higher weight and then you must go back to the specified weight on the next fill), they're just doing it at the dealership level for the whole fleet.
An oil with a higher viscosity (one with a higher value) may be better suited if the vehicle is operated at high speeds, or under extreme load conditions.
They also say this (copy and pasted from my wife's Toyota owners manual):
How do they get away with that ?
What year is hers?
So maybe it's been varying by model for the last few years. Just as an example, here's the T24A section from the 2024 Highlander and the same for the 2026 Highlander. 2024 still had that wording, 2026 does not2024
I think (well, no doubt they do) Toyota complies because they do still recommend 0W-20 viscosity very specifically. They also include the "must switch back..." phrasing too.
Both screenshots say "however, it must be replaced..."So maybe it's been varying by model for the last few years. Just as an example, here's the T24A section from the 2024 Highlander and the same for the 2026 Highlander. 2024 still had that wording, 2026 does not
That's because CAFE is standing in the corner with a bat.Both screenshots say "however, it must be replaced..."
A similar statement about using thicker oil when the driving conditions are more demanding (ie, it provides more engine protection) are in all the Toyota owner's manuals.Shocker I say I say Shocker
Actually surprised they put it in writing.
I'm talking about the bit that says "an oil with a higher viscosity (one with a higher value) may be better suited if the vehicle is operated at high speeds, or under extreme load conditions."Both screenshots say "however, it must be replaced..."
