You have roughly the same amount of wind capacity as Ontario (a little over 5GW), but about 1/3rd the nuclear capacity (with OL-3), yet nuclear is the largest single source and this is from before OL-3 was online:I was agains wind power about 10-15 years ago, when our government paid fairly big subsidies for those ”futile windmills”. To my surprise, today the wind power here is totally profitable on its own without any subsidies, and there’s a lot of them built every year with private money only. Whoa, didn’t see that coming.
Give them another 10-15 years, and they will fix also the duck curve, I’m sure. For example with local peaker hydrogen plant (create hydrogen when there’s excess electricity, ’burn’ hydrogen back to electricity when needed).
We’ll get there, just need some time (some decades).
Replace coal with nuclear and wind/solar and I think you are on a good track. Natural gas can be kept as a peaker for nowMe? I’d flatten it with coal or nuclear baseline capacity and natural gas peaking units. But maybe that’s just me.
lpg tank up to 8 bar in very hot summer, winter 1barOne thing just occurred to me, I recall when discussing cars that are converted to run natural gas or LPG, you had people questioning the safety aspect of having this type of fuel on board. Despite a proven track record in other countries around the world and taxi service here in NA.
Now we are discussing hydrogen and people don’t seem to be concerned at all.
Interesting how the perception of safety is so fickle.
We have at work LPG driven trucks, but you need to start them with diesel. Aslo passage cars from VW offering bio/LPG cars in EU.One thing just occurred to me, I recall when discussing cars that are converted to run natural gas or LPG, you had people questioning the safety aspect of having this type of fuel on board. Despite a proven track record in other countries around the world and taxi service here in NA.
If you’re a scuba diver, homebrewer or work in fire safety around fire extinguishers/SCBAs, you’re probably familiar with a compressed gas tank needing a hydrostatic test and visual inspection every 5 years. Else, you can’t get air/gas fills. Composite tanks haven’t caught on in scuba - buoyancy and after Luxfier had some failures of them in use, diving scrapped them.lpg tank up to 8 bar in very hot summer, winter 1bar
cng tank ~250bar - mandatory periodic tank checks
h2 tank 700bar
cng
Fixed it for you.From wikipedia:
A hydrogen internal combustion engine vehicle (HICEV) is a type of hydrogen vehicle using an internal combustion engine. The absence of carbon at the tailpipe, means that no CO2 is produced, which eliminates the main greenhouse gas emission of a conventional petroleum engine. The efficiency of a hydrogen combustion enginecanbe similaris not even close to that of a traditional combustion engine, when the full energy production cycle is taken into account.
transport is a non-issue as all sorts of pressurized highly flammable gas moves across the country everyday. when is the last time a propane truck blew up or any other industrial gas incident.I'd be surprised if 5% of the 5% comes from "renewable" electrolysis. IIRC, it's grid power, which is mostly not VRE.
Any industrial process is most efficient (hydrogen production included) running flat-out 24/7, which means it can't be economically powered by wind and solar. Hydro? yes, nuclear? Yes. Running it intermittently not only affects the economics, it's harder on the equipment resulting in higher maintenance costs.
All that said, hydrogen presents massive challenges beyond just production. Transporting it is a huge issue, as is having Average Joe handling thousands of PSI of an invisible odourless and highly flammable gas. EV's are, in comparison, massively simpler, given the fuelling infrastructure is already mostly in place and the hazards (electricity) are currently handled by Average Joe daily.
Hydrogen is significantly more challenging to handle and transport than propane. It's extremely leaky, invisible, has no smell, and requires extremely high pressure. Some of the challenges are outlined in this article:transport is a non-issue as all sorts of pressurized highly flammable gas moves across the country everyday. when is the last time a propane truck blew up or any other industrial gas incident.
no different then how propane cars were so "dangerous"
Hydrogen transportation and distribution pose specific issues in terms of safety. The issues are strongly related to the chemical and physical properties of hydrogen: its ability to embrittle materials, its ease in escaping from containment, its wide flammability range, and the limited amount of energy needed to ignite it, all represent barriers to safe use. At the same time, its extremely low density is a guarantee that the gas will likely ascend instead of forming dense dangerous clouds as other hazardous gases do.
The very wide flammability range does not work in favor of safety but the buoyancy decreases the possibility of cloud formations at low heights (where human receptors are closer). In the event that large clouds are produced, these can be lately ignited and cause explosions. Another possibility is the formation of jet fires due to leakages in pipelines under pressure with an ignition that is not too much delayed. The safety distance for receptors, both humans and buildings, depends on many factors. A good reference for evaluating this distance was presented by Jo and Ahn (2006), and it is proportional to the square root of the steady state pressure in the pipeline and to the diameter of the pipeline.
Liquid hydrogen spills show an initial behavior that can lead to the formation of a pool. However, the liquid phase is immediately accompanied by the presence of hydrogen vapor, which is quite cold and dense. The temperature of the fluid is so low that it may lead to the solidification of the other air components such as nitrogen and oxygen. The particle of solid oxygen can mix with liquid hydrogen and prepare a potentially explosive mixture that could self-ignite. A jet fire can also originate which again is dependent on the quantity of hydrogen available. Further experimental works are expected on this topic as liquid hydrogen, as seen, is one of the most deployed forms of hydrogen in state-of-the-art distribution systems.
Pick a lane guy.and so is the list of gasoline and other explosions.
The answer is last month. And a couple months before that. You don't get to hand wave away your above statement, concur with what I've presented (that the list is extensive) and then claim that something even higher risk and more challenging to handle and transport isn't an issue:anderson said:when is the last time a propane truck blew up or any other industrial gas incident.
The issue is that hydrogen is significantly more challenging than petroleum products on the handling and transport front, and, as detailed in the Science Direct article, some of the specific risks are extremely unique because of hydrogen's behaviour and interaction with materials and other gasses, which differs, wildly, from that of fossil sources.i still fail to see the issue.
We have trucks at work that run on LPG. They are forbidden to park inside the factory without supervision. There is a reason for that.transport is a non-issue as all sorts of pressurized highly flammable gas moves across the country everyday. when is the last time a propane truck blew up or any other industrial gas incident.
