Doesn't need to be clean, most important is carbon neutral. All Castrols Edge oils in eu are carbon neutral for exampleIf people are smart there is no way hydrogen power will ever be the answer unless we live on Jupiter and can suck raw hydrogen from the atmosphere and compress it.
Companies like SoCalGas insist that their hydrogen will be clean, but that’s a lofty promise to make when currently 95% of hydrogen energy comes from fracked gas. The other 5%, called “green” hydrogen, comes from splitting water molecules with electricity from renewable energy.
But even if industry could produce “green” hydrogen at scale, it would still be wasteful and inefficient. Compared to renewable-powered batteries, which are 80% efficient, hydrogen fuel cells are only 30%. That makes hydrogen far more expensive than renewable-based electric power.
What’s more, hydrogen is a thirsty power source. Throughout its life cycle, each megawatt-hour of “green” hydrogen consumes at least 5,000 liters of water. Compare that to solar, which uses 20 liters per MWh, or wind, which uses just 1 liter per MWh.
FIFY. People care far more about their wallet, than they do their, "carbon footprint".Doesn't need to be clean, most important is cheap and available. All Castrols Edge oils in eu are carbon neutral for example
actually no, just waitThe engine sounds like a winner. Making the fuel for it, not so much. Like prizm said, unless we discover a large, cheap source of hydrogen to power it, it ain't happening.
This is a classic example of putting the cart before the horse. You have to construct the fuel supply and delivery network, BEFORE the engine that runs on it. Not the other way around.
This is the big problem with EV's, along with Toyota's hydrogen powered Mirai program that flopped. You would think they would have learned their lesson. But instead it would appear Toyota is falling into that same rabbit hole..... Again.
For what?actually no, just wait
You missed the major issue. Hydrogen takes an enormous amount of power to separate from other elements. It is barely present in our atmosphere, which contains just 0.00005%.Doesn't need to be clean, most important is carbon neutral. All Castrols Edge oils in eu are carbon neutral for example
Yes and no, i do care more about my wallet. My neighbor care more about being political correct. Carbon footprint will arrive to USA sooner or later. EU is just way ahead with thatFIFY. People care far more about their wallet, than they do their, "carbon footprint".
"Sooner or later" we'll all be dead. Besides, that whole "carbon footprint / carbon credits" nonsense came straight from Al Gore......... Carbon footprint will arrive to USA sooner or later.......
totally agree with you, but it doesn't need to be greenYou missed the major issue. Hydrogen takes an enormous amount of power to separate from other elements. It is barely present in our atmosphere, which contains just 0.00005%.
that's also correct"Sooner or later" we'll all be dead.
hard to response to you when you edit your posts after i responded to you, But...Also i agree on your edit. But when it comes to carbon neutral we are much ahead on that"Sooner or later" we'll all be dead. Besides, that whole "carbon footprint / carbon credits" nonsense came straight from Al Gore.
And Europe is hardly a model for energy distribution or consumption. They might be if everyone did the exact opposite of what they do.
Spare us the moral preening.hard to response to you when you edit your posts after i responded to you, But...Also i agree on your edit. But when it comes to carbon neutral we are much ahead on that
But that water is made again by the burning of the hydrogen in the engine and it comes out the tailpipe.If people are smart there is no way hydrogen power will ever be the answer unless we live on Jupiter and can suck raw hydrogen from the atmosphere and compress it.
Why? Would it have been any different if I had just gone ahead and wasted the bandwidth by creating yet another post saying the same thing?hard to response to you when you edit your posts after i responded to you,........
Two important points -But that water is made again by the burning of the hydrogen in the engine and it comes out the tailpipe.
