CATERHAM said:dailydriver said:How do the MRVs compare between these two oils and also M1's AFE/EP 0W-20, for extreme cold weather use??![]()
My friend your memory is slipping.
You got all the spec's for Sustina 0W-20 a while ago and it's MRV is pretty much on par with M1 AFE/EP 0W-20 at 9,630cP..
We don't know what it is for the other OEM 0W-20s but for the original Nippon Oil made version of TGMO it's MRV was 18,000cP.
The intention of the OEM 0W-20s like TGMO is to be as light as possible at more typical start-up temp's, not extreme cold.
So, for someone in a VERY cold climate, for a WINTER OCI, you would suggest either the Sustina, or the M1 EP/AFE over the TGMO??
Just how cold does the ambient temp have to be for the TGMO to have a flow/pumping problem as compared to the M1 and Sustina products??![]()
(I guess I cannot grasp the concept of MRVs vs. V.I.)![]()
Yes if you are routinely starting an engine unaided at Temp's that will hit -40 degrees then either M1 or Sustina would be your best choice.
But if you're never seeing near that cold it's VI that matters most and for 0W oils viscosity graphs are probably good down to -20C or even -25C. And if one still wants to use TGMO at super cold Temp's it will still work very well especially compared to a heavier grade like M1 0W-40.
