Well after getting my last UOA, I'm almost certain it may be the seal.
For the last 100K I have had a high SI problem.
Part of the problem was the fact that I have a high milage truck (387K). From 300K to now, I have replaced the Valve cover Gasket, Oil pan Gasket, Air filter every 8-10K, rear main seal, EGR filter material has been replaced...
And the last two OUA seems to indicate possible FRONT MAIN SEAL.... my only conclusion because all other seal material has been replaced, and please don't anyone tell me the engine needs to be dis-assembled... well please tell me what you would think is the problem.
Never before have I had a problem with any wear material, perhaps because of a by-pass, but I'm sure that did not MASK everything... I mean even with it off, most of my numbers were in the low single digits and less, now they are on the move.
Does anyone Know when the typical Front main Seal goes on a 1997-Yacoma? How much problem is it to replace? (I.e. hours / dollars)
